Question about Sony PlayStation 3 40GB System
This is what happen my regular Ps3 av jacks that came with the ps3 broke so i went to game stop and got some new ones but i accidently got hdmi jacks then i used those for a day and the color was in black in white cause i dont have a flat screen. Then i went and returned them and got the regular Ps3 av jacks and now i dont have a picture and i already reseted my Ps3 like 5-times.
    Novelist:
  • 149 Answers
You have to do the video reset once you use HDMI the ps3 stays in HDMI mode till you do video reset
to do video reset:
when ps3 is in standby mode(red light) press and hold the power button till you hear the second beep then release and that resets the video.
hold power button............beep..............beep.......release, done.
Posted on Sep 27, 2009
    New Friend:
Try calling someone who nows about this in paricular a electronic store
Posted on Feb 27, 2013
Anonymous
  • 67 Answers
SOURCE: What to do with my Ps3??
Your PS3 auto-adjusted to the HDMI Input cable, so you will need to find somewhere that you can either get an HDMI cable or a HDMI TV, so you can view the screen. Then you can hook up the A/V jacks and go to your Videa and Audio Output Settings and choose them, disabling the HDMI hookup selected. Then you'll be back in business!
Posted on Sep 29, 2009
Help with insignia 24 inch flat screen? the av channel will not show the channel where i can play my ps3?at?
It sounds like yoru PS3 has stopped handshaking with your tv. It can happen. It's possible your brother disrupted the connection by unplugging the PS3 before it was shut down. You can try turning on the PS3 first, and then turning on the tv, or vice versa. If that doesn't work, you may need to invest in a cheap HDMI splitter, to plug the PS3 into, and then send the signal from the splitter to the TV. It has happened to me with a computer with the same hardware, once with an LED tv, and once with my surround sound receiver, completely out of the blue. You can try switching HDMI cables, sources, doing putting the tv into maintenance mode and resetting the software. If none of that works, your only option may be to use an HDMI splitter. I did extensive research and read numerous reviews before I settled on this model, due to many recommendations:
ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P & 3D ' Model: VHD-1X2MN3D
It's available on Amazon here:
Amazon com ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P 3D Model...
Just in case your HDMI cable was damaged when your brother unplugged it, go ahead and get yourself a decent HDMI cable. The Amazon HDMI cables work just fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 07, 2017 | Video Game Consoles & Games
The new AV cable will not fit into the slot in the ps3. Used a regular composite cable prior to trying the new HD cable.
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks .
click here to download repair guide... u can do this by yourself....
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 was switced to hd and wont switch back to a av cable
You have to set it back to the regular cables the same way you did with the HDMI
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Sep 29, 2009 | Video Game Consoles & Games
I can not get ps3 to show on TV. It turns on, green light in front with blue light with disk in.
you might have it stuck on a different video output e.g HDMI or AV. i had the same problem when i took my ps3 to a friends house mine was stuck on HDMI from my tv and i put it on my friend's tv on AV and it didnt show up i thought my ps3 was broke but when i got it home i realised you have to change it from HDMI to AV through settings on the XMB on display settings. hope this helps
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
It turns on but nothing happens
all depends what cables you are using.if you are using hdmi it could be that the hdmi format is not supported because it has to be hdmi 2.0 and yes thier is a difference.
If you are using componet cables make sure they are plugged into the correct inputs.
if you are using av cables they could be broke.
if none of these help with the problem then i don't have an anwser for you.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
No main menu or video shows on tv
u need to set the display output back to standard av cables. search online and there should be steps on how to do this.
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
New HDMI problem
my brother had this issue with his PS3, he simply went into the settings with the av cable and hooked the hdmi up at the same time and changed the settings from auto to manual.
Mar 12, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Sony PlayStation 3 40GB System Questions
Sony PlayStation 3 40GB System Logo
211 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
