Jet 708531 Jwp 16OS 16 Inch 3 Horsepower Open Stand Planer, 230 Volt 1 Phase Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for manual for a Jet-16 3-phase machine for drilling and milling that I bought
Anonymous
Level 3:
  • Master 582 Answers
  • Posted on Sep 26, 2009
Anonymous
Master
Level 3:
Answers
582
Questions
0
Helped
238773
Points
1711
GO ONLINE AND TYPE IN / JET 16 MILLING NACHINE MANUAL
THE PAGE YOU WILL NEED IS ASAVAGE.DYNDNS.ORG/JET 16
AND CLICK ON THE MANUAL IT'S 19 PAGES
Crysta Apex 707 error code E541
The new line-up of CRYSTA-Apex series CNC coordinate measuring machines
1helpful
Manual-- hafco milling machine, hm-32
Hello -
You will find the link to download the Instruction Manual here:
https://www.machineryhouse.com.au/M121
Best wishes.
Jan 08, 2019 • Drills
2answers
What am I able to drill through with a milling machine?
Milling machines are very versatil, they are able to cut through almost all solid materials.
2answers
Whats the difference between a milling machine and a drill press?
a drill press holds the work piece stationary to be cut, a milling machine moves the work piece to the milling cutter.
Need a operator manual for a jet milling machine jvm 830
Call JET Tools Customer Support and they'll email it free.
The adjustable chuck on my sons Jet JHM-610 comes off when using it in the milling function. What is the best fix for my situation? It is coming off at the taper.
You should really be using end mill tool holders for milling. The torque is too great for drill chucks. You will get better results machining with surface finish, size as well as longer tool life. Side note..take care with reassembly of drill chuck. Tapers must be dirt and burr free or chuck will have run out as well as taper lock will break and come apart on you more often. If there is damage to the tapers replace the arbor and or chuck with new.
I have a Drill press 16 Speed, Model BT1001A and the On/Off Switch and light switch has all been removed. How do they go back on the switch and the sequence? How do I get access online to the schematic...
This is a difficult question. There are Euro, American and Chinese motors used, the most common is the chinese one phase motor at 110 volts. This is again complicated by the fact the chinese changed the hookups between 1999 and present models. In 1999 the Grizzly type clones from China had a six screw terminal block with the supply wires being: BLUE, BROWN, BROWN, BLACK, GREEN/YELLOW. with U1=BLUE, V1=BRN, Z1=nil, Z2=BRN, U2=BLK, V2=nil and you could reverse the direction of rotation by reversing the two brown wires on V1 and Z2. The new chineese wiring has made some changes to this and can be viewed on the details of any eBay site selling new Grizzly metal lathes of the 12X36 size of which they make about 9 varieties, keep reviewing each one, there are about two ads that give actual pictures of the new terminal blocks they use which have two flat bar jumpers right in the block and they use different terminals within the six on the motor.
My example is for a 1999 Chineese electric motor for the AT-400 Lathe/Drill/Mill which uses a generic
WANNAN 1 phase electric motor 3/4 HP, 1700 rpm, 11.0 Amps, 110 Volts, Date 99/7
American and Euro wiring tends to have other colors like white, orange, etc. and up to twelve of them so you have to research the exact motor, where it was made, and what date to get the right info. then you have to draw diagrams to match your switch wire hookup to the plate which is on the motor just beside the terminal block. Mine had two reversing switches and two motors plus another switch which selected between power to the mill or power to the lathe. Using the above color codes it worked right the first time only because I researched and then charted out every wire and did continuity testing to ensure functionality without worn-through or loose contacts. Also, unplug the machine and leave unplugged overnight before touching the wires as the capacitors carry a big charge at high voltage and hold it a long time.
2answers
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
What is meaning for absolute nodal coordinate formulation? how to apply damping force into absolute nodal coordinate formulation?
Must be a China made Mill. Their English does not make sense.
I assume it is referring to taking looseness out of a slide or moving part by adjusting the ways or clamps very gently.
Top Jet Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Jet Craft and Hobby Expert? Answer questions, earn points and help others
