Electronics - Others Logo
Posted on Sep 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fans no longer turn on and the inverter shuts
The fans no longer turn at all and after a while the unit will over heat and shut down
Craig Butler
Level 3:
President:
  • Master 1,730 Answers
  • Posted on Sep 26, 2009
Craig Butler
Master
Level 3:
President:
Answers
1730
Questions
0
Helped
697174
Points
4778
YOu can replace the small fans and it will work fine. Go to newark,com and they have very small cooling fans like that.Same ones that computers have for cooling. You will have to open things up and get some numbers and dimensions.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
What does a P6 code mean after unit starts up and shuts down?
Really need make and model (what it is) in questions like this!
A P6 error code occurs when the pressure of the system goes below a certain value. This is caused when the pressure of the system is too low for the unit to operate. ... If the pipe isn't hot, then the system is low on refrigerant and there could be a possible leak somewhere.Mar. 25, 2021
P6 error code - Low pressure protection - Senville
How To Fix a P6 Mini Split Error Code (Cooper and Hunter)
https://www.hvachowto.com > how-to-fix-a-p6-mini-sp...
Nov. 12, 2019 - A P6 code on a mini split is an Inverter Module (IPM) Protection Error. When the voltage signal Inverter Module (IPM) Protection sends the ...
2answers
Monitor's backlight inverter shuts down.
what is the exact model maker of the tv...? and also if you can provide the part # that would be great.!
2answers
AC Condenser motor will stop at 1pm but inside unit is still running but no AC. If I turn the AC unit breaker unit off and then an hour later turn it back on. The unit runs fine all day until 1pm. Had a...
Hi, the tech should have been able to figure the stat out with out a manual to see why the condenser is shutting off at 1:00 P.M. This is unusual for this to happen, unless it was winter and this is a heat-pump going into defrost, but just the fan would shut down. Does this unit have a box on it that was installed by your electric company that shuts the unit off during high peak conditions in the summer? This would cause it to shut down at the same time everyday. If not, it would have to be something in the thermostat that is set for it to shut off at that time. It still does not make since, as it would shut both the indoor and outdoor unit off, not just the condenser. Are you saying that just the condenser fan motor is shutting off, but the compressor continues to run until it shuts off on high head pressure when the fan stops, or does the complete outdoor unit shut down fan, compressor and all at that time??. It sounds to me like this outdoor unit has a time delay relay that has a fault in it may be shutting it off at this time daily? Please let me know if its just the condenser fan motor that shuts off, or if the complete unit is shutting off all together, this will help .
Sincerely,
Shastalaker7
A/C, Heating,
Unit runs but no ice.in searay boat fan does not want to come on. Unit runs. .Live in chatham ont. canada. what to do. dave @[email protected]
My unit turns on works for a while then shuts down, fan would not re-start every cycle, causing over heating and shut down, cleaned the fan, oiled the bearings, cleaned all the elec. connections, seems to work now.
Honeywell Thermostat RTH 7500
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
4helpful
2answers
Vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
1helpful
2answers
No Heat!
Sometimes too much dust around the heating elements can cause the heater to switch off to prevent a fire. Check for dust build up first. You can try using a can of compressed air that can be found at many electronic stores.
Top RoadPro Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
