General Electric Clothes Washer Timer - WH12X10254 Logo
Posted on Sep 25, 2009
Washer does not move to next cycle; does not turn off automatically
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
233
Points
MY GE WASHER CONTINUALLY WASHES AND DOES NOT DO ANY OTHER CYCLE OF THE WASH IS THE PROBLEM MY TIMER IS MESSED UP??
2answers
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Washer will not advance to the next cycle unless you put it there your self. will keep running in a cycle until you move it out of a cycle.
THE CLOSK PROGAM IS EAD HAS TO BE CHANGER IT PERMITTS THE AUTOMATISM OF THE PROGRAM WHEN DEAD YOU DO ALL BY HAND
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
1helpful
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
