Xerox Phaser 7750DN Laser Printer Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a xerox 7750, error code 9-913
I have a xerox 7750, just installed a new image unit and now i am getting an error message 9-913. HELP PLEASE
YOUTUBE-CLOUDYDREAMS
Level 2:
Guru:
  • Expert 110 Answers
  • Posted on Oct 22, 2009
Expert
Level 2:
Guru:
Answers
110
Questions
0
Helped
57589
Points
307
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2189
Points
In imagining unit search about connector and just replace it with 7750 connector it will fix problem ,for new connector you can ask your tech-nation or contact me
[email protected]
Anonymous
Level 1:
New Friend:
  • Posted on Aug 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2189
Points
The problem come from the electronic part of the image unit. It can be easily replaced by customized part. It can be easily buy on ebay.
Anonymous
Level 2:
Novelist:
  • Expert 125 Answers
  • Posted on Sep 27, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
125
Questions
0
Helped
90961
Points
262
Hi sorrosmum:
I can not find the error 9-913 in the service manual so i am giving you this info to try. Hope this helps.
1 1. Replace the imaging unit reporting the
error.
2. Does the error still appear?
Go to step 2. Complete.
2 1. Remove the imaging unit from the
problem location and inspect the
connector.
2. Is the connector damaged?
Replace the
imaging unit plate
assembly.
Troubleshoot the
wiring. If wiring is
OK, replace the
engine control
board.
3 Related Answers
Anonymous
  • Posted on May 20, 2008
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Anonymous
  • 2072 Answers
  • Posted on Sep 26, 2008
SOURCE: I keep getting Error code
That is the fuser fan. It is either running slow or stalled.
You have to remove the rear and top cover to access it. It is located on the upper right back side of the machine looking from the rear.
You can remove the fan, peel off the silver label then remove the small rubber cap in the middle. Behind that rubber cap is the fan bearing, It is dirty and needs to be cleaned.
You can flush it with alcohol then add a highly refined oil to that bearing, Replace the rubber cap and then clean the outside with alcohol, then put a small piece of tape over the rubber cap to keep it in place. Most of the time. I would say 75 % of the time that will fix the problem. If it doesn't fix it in the long term you wol have to replace the fan. Don't call Xerox directly, Go onto google and look up a business called " the parts drop". Call them and ask for Britt or Joe> I dont work for them, but have purchased parts from them for years. They are reliable, fairly priced and honest. Great people to do business with.
elmojado
  • 110 Answers
  • Posted on Oct 29, 2009
SOURCE: hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Xerox 7435 error 041-340 how to solve error
Xerox 7435 error code 041-340 indicates a problem with the yellow imaging unit. Here are some steps to solve the error:
  1. Power off the printer and unplug it from the power source.
  2. Remove the yellow imaging unit and check for any damage or leaks.
  3. If the imaging unit appears to be in good condition, reinsert it firmly and make sure it is properly seated.
  4. Turn the printer back on and check if the error message has disappeared.
  5. If the error persists, try replacing the yellow imaging unit with a new one.
  6. If replacing the imaging unit doesn't solve the problem, you may need to call a technician to troubleshoot the issue further.
It's worth noting that error code 041-340 can also be caused by issues with the developer housing, toner cartridge, or other components. If none of the above steps work, it's best to contact Xerox support for assistance.
tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
Xerox phaser 7760 not detect the missing fuser, image units
there is nothing to look for it told you it is past the end of it's life so buy a new unit
7750 power on self test error. "please install config chip", "call service"
Did you ever figure this out? I'm having the exact same problem right now & can't afford to call in a service guy. If you know, please send a message to [email protected]. Thanks!
5helpful
2answers
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
3answers
Print quality problems after installing imaging unit.
Put the old image unit back in, if it prints normaly then you might have bought a defective image unit.
2answers
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
3helpful
2answers
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
2answers
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
