Seiko Pulsar watch Logo
Posted on Sep 22, 2009
Set day, date & time on pulsar analog & digital watch
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Sep 22, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
25509
Points
89
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
2helpful
Setting time day date in ESQ Aerodyne
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
2helpful
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Day and date out of sync with time
Try rotating the analogue hand 12 hours ahead of the current time
25helpful
Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
1helpful
2answers
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 • Watches
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
