Nikon 7431 LaserCaddy Rangefinder Logo
Posted on Sep 22, 2009
Even with new batteries, this Nikon golf rangefinder will no longer pick up the flag for distance measuring. Only large trees etc... (Never damaged, worked fine for more than six months before failing/ small targets). Changed batteries again; STILL no joy picking up flag outside of 100yards, Please help!?!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1057
Points
On my Laser 500 G I held both buttons down simultaneously for a short time and it began finding pins again.
3helpful
3answers
What is the difference between Hunting vs Golfing Rangefinders?
If you want to buy a rangefinder then you would have a question at some point. Can you use a rangefinder for both golfing and hunting? Can you save a few bucks buying one rangefinder?
The answer is Yes, you can. You can use a laser rangefinder for both activities if you choose a smart device that has features to serve both golfing and hunting adequately. You just need to know the basic differences between golf and hunting rangefinders and some limitations.
Fast of all you have to know, what is golf rangefinder and hunting rangefinder.
Golf Rangefinder Golf rangefinders seek for the nearest flag stick for the measuring the distance in an open field.
Hunting Rangefinder
The rangefinders always are in "Distant Target Mode" by default to spot wildlife in wooden terrains. This target set automatically ignores close objects that could obstruct your view.
Here I wrote the 3 difference, you should remember that:
1. First Target And Distant Target Modes
Golfers need "First Target Mode" to detect the near objects like flag or pin in an open golf ground. Hunting rangefinders rarely good at detecting close objects. For hunting, "Distant Target Mode" is appropriate to range a target past the wood. Modern rangefinders come with toggling options between both first target and distant target modes, but they are expensive.
2.Quick And Accurate Reading
Golfing rangefinders detect the object quickly, and hunting rangefinders give the accurate reading. It is true that golf rangefinders do not need to be as precise as hunting one. Hunters want to make sure that their prey can be perfectly located.
3. Magnification Strength
You might be aware of the fact that Hunting rangefinders always have more magnification than the Golf Rangefinders. Golfers need the distance of the next hole, which could be maximum 400 yards. For the bow hunters and hunting, 400 yards rangefinders are also appropriate. In case of rifle hunting or long-distance shooting sports, you will be needed maximum 1000 to 1500 yards ranges.
Now you know what the basic differences between the golf and hunting rangefinders are. You can start choosing your suitable one.
Apr 02, 2018 • The Optics
Is the Nikon Prostaff 3 Rangefinder good for the golfer?
Nikon Prostaff 3 Laser Rangefinder
You would obviously expect something superior from Nikon. Well, this renowned company will not disappoint you. They have maintained their expert quality, but that does not make the product expensive. Nikon Laser Rangefinder gives you a crystal-clear image at a very low price.
With the launch of Nikon Prostaff 3, two categories of rangefinder seekers have got something to rely on for their ranging needs. Golf players belong to one category while others who want to get top features but maintain a budget belong to another category. Many hobbyists and professionals are getting keen on using rangefinders. It enables hunters and golfers to have a smooth field of view. It gives you enough range and brightness for clear sight. Nikon Prostaff 3 Laser Rangefinder has created some buzz among outdoor lovers. The multicolored display is adequately bright and able to show distances in meters and yards.
There is a continuous measurement mode that facilitates multiple measurements without requiring users to make any additional adjustments each time they switch targets. This mode helps users to gauge the accurate distance between particular objects and their current positions.
The built-in slope compensation deals with the changes in slope heights almost accurately. Making precise measurements at different angles up to 89 degrees becomes a breeze.
Laser 400. Where can I get a battery cover?
Battery Cover Nikon Sale‎
battery-cover-nikon.compare99.com/‎
Up To 70% Off Battery Cover Nikon
Battery Cover Nikon
Wont measure distance
Must see if the battery is in correct polarity and is set right . If power comes without any measurement, thenit is possible that the laser is not active , the beam is not readback , the processing is faulty for the return signal.
Might have the main board processor faulty.
2answers
I purchased a new LR 559 Callaway golf rangefinder from a QVC auction. The problem with it is it isnt even close to accurate. I have a measured archery range back to 65 yards and the rangefinder is way off...
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
7helpful
Pinseeker 1500 has trouble picking up flags over 100 yards away
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
mr tech geek Rate me if you can...or find out this is the truth!!!!
Bushnell Repair Technician
Service address:
Bushnell Repair Centre
8500 Marshall Drive
Lenexa, KS 66214
send $10 for return shipping
send your problem statement and phone number.
Their number is 800.423.3537
10helpful
Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Unit "cannot measure" at any distance
Had the same problem... Pushed the mode button and the power button simultaneously for 30 seconds, then it worked again...
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
