Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
42 inch LG Plasma TV Lost Picture
Hi there, I was watching my 42 inch LG Plasma TV last night, and I heard a click sound and  then lost picture, the sound is working OK, what do you think the problem is
I was watching the TV and the image just went black. I can still hear the tv but not picture!
  • 4 more comments
  • nazario Dec 14, 2007
    Hi
    Thank for you help!
    i've tried the menu screen via control and it still doesn't work!
    I've had the TV for 2 years and its used daily for a at least 5 hours or more a day!
    Help!
    Nazario
    Hey!
    i went to that site you told me and Im not sure if this is the lamp that goes on the my tv.
    I bougth my tv in australia and in the back it says
    Sales model: 42PX4DV
    Model No: 42PX4DV-AA
    Again is a LG Plasma Tv
    I copied and pasted the information below from the site you asked me to get the lamp from.
    It says is for DLP TV???
    Availability: Immediate
    This lamp is used in the following LG DLP television model(s):
    RE44SZ20RD
    RE44SZ21RD
    RU44SZ51D
    RU44SZ61D
    RU44SZ63D
    RU52SZ51D
    RU52SZ61D
    RU52SZ63D
    Email a friend about this item.
    This is the original manufacturer replacement lamp used by LG in their DLP TV housing part # 4930V00301.
    Please note, this is the lamp only, and is intended to be installed in your existing housing.
    Overnight and International shipping are also available.
    PRICE: $179.00
    Home · About Us · FAQs · Contact Us · Testimonials · Cart · Checkout · Policies
    © 2007 DLP Lamp Source
    Am I in the rigth track?
    Thanks again for your patience,
    Nazario
    (Sales model: 42PX4DV
    LG Plasma Tv)
    last night, and I heard a sligth click sound and then lost picture,the screen went Black, the sound is working OK, what do you think the problem is?
    Help!
    Nazario
  • nazario Dec 15, 2007
    I checked in the back of the tv and it says-
    LG
    Sales model- 42PX4DV
    Model no: 42PX4DV-AA
    Product Code: 42PX4DV-AA. AAULLAD
    I hope this helps!
    Nazario
  • Anonymous Mar 20, 2014
    I was watching tv and suddenly lost the sound
  • Anonymous Mar 23, 2014
    Red light clicks on then straight off no picture or sound just a white flash
    Sergeant:
    Champion:
  • 231 Answers
If its a plasma .Then most definitely you have a YSUS,ZSUS and or Y drive board bad..I could not find part numbers for you with model you gave in the LG servicer website..But even if you have only the Y board bad ..It is recommened you change at least both Y and X .unless the Y drive is also bad..Please verify correct model ..I work with LGs all the time and I can get you part numbers..
Posted on Dec 15, 2007
  • 4,102 Answers
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
  • 4 more comments
  • paul proctor Dec 14, 2007
    Hi sorry i think i miss informed you was thinking of other problem not your sorry.
    The problem is deffinately the lamp needs replacing.
    Its not expensive to do and is possible to do yourself.
    If you think you are capable of doing this yourself then give these a try for the part you need okhttp://www.dlplampsource.com you should be able to get it from their.
    But if you are going to replace yourself remember you cant touch the lamp with your bare hands you have to buy some gloves ask in any repair shop and they will tell you the best ones to get because if you touch the lamp and their is any grease or anything on them it will blow the bulb strait away so its not worth the risk.
    Let me know how you get on ok.
    Hi disregard my first post as this can sometimes be the problem but only usually when the telly is about 3 to 5 years old so dont worry about that it is deffinately the lamp gone ok
    Hi ill have another look for you maybe the link i got of mate wasnt right link for your make and model ill have another look for you ill post back and let you know ok sorry for wrong info will post back looking now for you
    Hi just spoke to couple of people for you who repair these units in uk they both told me that not lamp problem it is either :
    scan drive pcb board or
    video buffer pcbs.
    Now they tell me both of these are expensive to replace they said it is either one of those or if your lucky then it could be the power supply to those parts ie the correct power not getting to them could be resistor or solder problem but it is usually one of the two problems with the pcbs whilst waiting for reply ill find out where you can get these parts and if it is possible to repair yourself.
    Ill look now for you ok
    Hi it deffinately wont be lamp problem as plasmas dont have lamps sorry for misinforming you but didnt check the info before researching your problem
    Hi the problem will be either of the pcbs so either goto repair shop and ask them to get them for you as the parts are hard to source without sending back to makers but repair shop should tell you about supplier they use as i live in uk its difficult for me to locate in your country.
    You could even try using search engine to look for parts.
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 92 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Posted on Oct 31, 2007
Anonymous
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
Anonymous
  • 15 Answers
ysus pcb that supplies voltage to the panel is faulty
Hi , was watching my 42 inch VIORE Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
Dec 22, 2017 | Toymax Viore 42 in. Plasma TV
Hi , was watching my 42 inch LG Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Sounds like a capacitor blew on one of the boards. Can you detect any burnt electronic smell? If the Cap blew on the Power Supply, you can either replace the Capacitor or replace the power supply board. The boards are between $79 and $149 depending where you get it. Some of the other boards, Y or Z Sus, are between $179 and $300. If you can't do it yourself, and with many 42" models selling for $649 to $899, it might be too expensive to fix.
You can find the boards on ebay or shopjimmy, youtube has videos showing how to replace them. Hope that helps.
Feb 15, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
609 people viewed this question
Ekse
RONALD CARTER JR
