When it gets to Spin cycle, stops and does not pump out water
Lid switch was broken off, but I have it temporarily clamped on with clip. Washer starts, goes through wash cycle, but when it gets to Rinse, stops completely, and water does not drain. I've tried starting it at various points on the different types of wash, but same thing all around. Will start on Rinse, but agitates, then stops. Any help would be greatly appreciated!
If the machine doesn't pump out the water there could be something clogged in the pump. The drain pump is attached to the motor with two flat clips. If you use a flat bladed screwdriver they are easy to remove. Pull it off of the shaft that turns it and see if the center piece facing the motor turns easily. If it does the pump is not clogged. If it is clogged then remove the two hoses attached to it as well. You can loosen the clamps from the hoses and move them away from the pump using a pair of pliers. Check the pump and the hoses for something that might be plugging them.
Your washer has a lid switch. If the switch is broken the washer will not spin. The pump is mounted on the motor. In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch Use this GUIDE to help you
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
check the lid switch,open the lid and use a pen or screw driver and touch the lid switch and listen for a click,if it doesn't click change the lid switch,if that's ok check the coupling,take off the front of the washer,take off the pump and then take out the two screws on the clamps that hold the motor in place,when you remove the motor you'll see the coupling,
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
If the washer fills and stops at the rinse cycle, and then
will not spin or drain, you more than likely have a defective lid switch.
If you open and close the washer lid and do not hear a “clicking” sound, the
switch has probably come loose, or has broken.There are two mounting screws that hold the switch in place along the
washer rim.Also, inspect the lid to
ensure the small plastic piece that pushes down on the switch when the lid is
closed has not broken off.This is
called the “lid strike”.If the lid
strike is broken or missing, the lid switch will not activate.If you diagnose the problem and need to
replace the switch, you can click on the following link for advice on how to replace
it:
If you need further assistance, such as where to get
replacements parts, please let me know.I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the
switch.Once the switch has been
replaced, the washer should spin and drain, which will prevent you from needing
to bail water.
Pretty much exactly what guest above me said. I have a lsq8543jq1 also, was stopping after agitation.
At first thought it was something more serious, since the dial seemed to make a humming/grinding/buzzing noise when it was switching to agitation cycle, but that seems to just be a timer before the drain/spin cycle kicks in.
I had a washer full of water, so rather than wait till I could get a part (or hand drain -what a pain), I just grabbed a paper clip and rigged the switch so it thinks the door is shut and voila, drains and finishing cycle as I type.
The switch is a safety device to prevent accidents; bad injuries could result if the door is opened while the washer is in spin cycle. I don't recommend this as a long term solution - especially if you have kids. I have 2 and will be ordering the new part asap.
