I have a beringer pmp 5000. Out of the box, I turned it on and the fan in the back is not operating. Does it have to get to a certain temperature before it begins to work?
for a 220v 50hz 1000w the fuse is T 6 3 AH 250v for a 100v 1000w the fuse is T10 AH 250v just make sertun thats wright or contact the manufacture address 18912 north Greek Parkway, suite 200 bothell, WA 98011 USA phone +14256720816
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Assuming you are using BOTH power channels for your main speakers, you MUST use external, additional, amplifiers for the monitors. There are ONLY two power amps in the PMP5000.
The other option is to run mono for the mains and use the second power amp (comes out on the Speakon connectors) to drive the monitors. For this, the little slide switch has to be on the middle position.
Doing this, you have to adjust the monitor volume controls for each strip.
With the AB switch at the center position Mon1/Main you control the volumes INDIVIDUALLY with the MON pot for each input that is a couple positions above each of the input sliders.
