SOURCE: distance over gas fireplace
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
SOURCE: My FEBO electric fireplace insert makes a loud
It sounds like you have a bad blower, and may need to replace it. I would recommend that you remove the housing cover, turn the heater on and verify that it is the blower motor. If that is the case, then you will want to order one from the manufacturer.
SOURCE: FEBO fireplace, GW2078 anyone have a website or
Not a solution, but a problem. I bought a 2078 from Big Lots 2mo. ago. Friday night, nothing. Checked plugin breakers, etc. Finally disaasmblrd the entire thing and checked every led,circuit, etc, and found nothing out of place or burnt. Now What? Taking it back to Big Lots today in a million pieces. Hope they can take a joke. Really like the outfit but need it to work.
