SOURCE: No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
SOURCE: BOSS BASS 600 - No Sound .
ITS BEST TO HAVE A SOLID REMOTE WIRE WITHOUT NE SPLICES WAT SO EVER
