SOURCE: Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
SOURCE: Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
