SOURCE: Samsung SW65ASP2
If you are sure there is sufficient water pressure at the hose, then your inlet valve is on the blink....replace it.(the unit where your hose connects onto) Oshie
SOURCE: Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
SOURCE: I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
SOURCE: how to open and clean the inlet water hose filter of Electrolux Dishwasher ESF 6150
all u need to do is hit it with a hammer
