Https://www.google.com/search?sxsrf=ACYBGNT6nLbuauU5ZByczrMC6cLaGIk6AQ%3A1581870161107&source=hp&ei=UWxJXtzCBND4aILKh_gH&q=General+Electric+Hotpoint+HTWP1400FWW+White+27.+The+washer+only+fills+to+half+on+the+rinse+cycle.+Ideas%3F&oq=General+Electric+Hotpoint+HTWP1400FWW+White+27.+The+washer+only+fills+to+half+on+the+rinse+cycle.+Ideas%3F&gs_l=psy-ab.3...223788.223788..226888...2.0..0.0.0.......1....2j1..gws-wiz.TGW-acS8eao&ved=0ahUKEwicr6DIvdbnAhVQPBoKHQLlAX8Q4dUDCAU&uact=5#kpvalbx=_n3NJXvmnM8GelwTnwpGQBQ28
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
SOURCE: Washer will not fill in rinse cycle.
hi, When the washer acts up in the rinse cycle, will it try and fill and then the water starts going out the drain hose? If this is the case, the drain hose is either needs to be raised to be as high as the top of the washer or, it needs to have a loose fitting where it goes into the drain pipe so it can have air **** back into the drain hose after it releases the wash water.
i know this is a lot of info that might not even be the answer but, I am giving you the most common fix. Please let me know if I have answered your question or let me know if I can assist you further.
If this does not seem to be the answer, maybe I need clarification.
Vic
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
