it could be that the water sensor is not Working properly telling the programmer that there's water in or out of the machine unplug the machine take the back off and locate a small 5mm pipe leading upwards take it off and blow gently into it you should hear a click and one when you let the air out if so the place you took the pipe from is blocked not allowing the sensor to work correctly use a pipe(smokers) cleaner or metal rod to clear refit the pipe and rear panel run machine eric
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
Sounds like you have a small clothing garment maybe a sock or similar stuck in the waste pump.
Take the lid off, Follow the bottom rubber hose inwards it connects to the waste pump, remove the hose from the pump and check inside the hose and the pump for clothing, make sure the pump spindle can spin round with your finger. Please make sure the power is switched off before removing the lid
