SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
SOURCE: cant control ringer volume
you just press ok after you are done using the up and down arrows(:
SOURCE: the side volume controls are touched when
No there is no options for turning off the volume controller. If you want the manual of how to use it download it from here : http://downloadcenter.samsung.com/content/UM/200808/20080826045904296_verizon_wireless_U310_Knack_ug.pdf
Rate me if it is useful!!
SOURCE: how do i change/control ringer
While the phone is on standby, press vol/bell
to hear the current ringer tone. Press
vol/bell
again while the tone is ringing to switch to the other ringer tone. The last
ringer tone heard will be selected as the phone's ring tone setting.
Get the manual from: http://www.google.com/url?sa=t&source=web&cd=9&ved=0CFcQFjAI&url=http%3A%2F%2Frsk.imageg.net%2Fgraphics%2Fuc%2Frsk%2FSupport%2FProductManuals%2F4300257_PM_EN.pdf&rct=j&q=presidian%20cordless%20phone%205.8ghz%20user%27s%20guide&ei=wPopTpSkE8zPmAXFhuitDA&usg=AFQjCNFGoj6kwkI8m_Hhi9K1t49wifNP2g&cad=rja
