SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
SOURCE: Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You
can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find
helpful exploded view diagrams and order parts here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My Kenmore Microwave Hood Combination Model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Basic Microwave Oven Troubleshooting Tips
heatman101
