Televison & Video Logo
Tibor Mocker Posted on Feb 13, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi,I have a problem with my TV. When the TV is switched on to the power supply, the red LED flashes. 2 times and after 3 seconds once. The screen does not light up, no sound. My TV Philips 47PFL7108K
Tom Chichester
Level 3:
Top Expert:
  • Philips Master 62,329 Answers
  • Posted on Nov 08, 2020
Tom Chichester
Philips Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
671121
Points
975369
Failing power supply
5 Related Answers
Anonymous
  • Posted on Jan 22, 2009
SOURCE: Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: [email protected]
Anonymous
  • 423 Answers
  • Posted on Feb 11, 2009
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Anonymous
  • 90 Answers
  • Posted on Feb 23, 2009
SOURCE: philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Anonymous
  • 44 Answers
  • Posted on Feb 28, 2009
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Anonymous
  • 6784 Answers
  • Posted on May 21, 2009
SOURCE: TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
Samsung 40EH5300 LED TV backlight flashes continuously when power applied. No picture.
You can find a solution on Youtube also google the problem or consult manufacturers page.
PANASONIC VIERA TX55as802b will not switch on red power/standby light blinking once every 3-4 seconds have been told its the screen and it cant be repaired can anyone confirm this or help.thanx
The manual says nothing about the power light flashing at that rate. Unless an expert tells you that's the specific indication for a failed screen, I wouldn't believe it. Most TV's will give you sound even if the display has failed.
Try resetting it by unplugging and waiting 60 seconds before plugging it back in.
If that doesn't work, most likely the power supply board needs to be replaced. Or possibly the T-con board.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Ways to fix red lights blinking four times
Red Power LED
flashes once
every two
seconds.
OR
Red Power LED
flashes four
times, once
every second,
followed by a
two second
pause.
None Power failure
(power supply is
overloaded).
1. Check that the voltage selector,
located on the rear of the power
supply, is set to the appropriate
voltage. Proper voltage setting
depends on your region.
2. Open the hood and ensure the 4-wire
power supply cable is seated into the
connector on the system board.
3. Check if a device is causing the
problem by removing ALL attached
devices (such as hard, diskette, or
optical drives, and expansion cards).
Power on the system. If the system
enters the POST, then power off and
replace one device at a time and
repeat this procedure until failure
occurs. Replace the device that is
causing the failure. Continue adding
devices one at a time to ensure all
devices are functioning properly.
4. Replace the power supply.
5. Replace the system board.
21helpful
2answers
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
