Tablets & eReaders Logo
M
Michelle Kissenkotter Posted on Feb 11, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus tablet Zenpad10: after factory reset Setup Wizard is crashing
I just did a soft factory reset on my Asus Zenpad 10. The tablet restarted, and then opened the Setup wizard. I selected my input language, and then was taken to the next screen to select a wifi connection. I connect to my wifi network and selected "next", and I receive an error message indicating that the setup wizard app has stopped and needs to restart. Then the first page of the setup wizard opened again (selecting the input language). I have gone through this cycle nearly a dozen times (trying to turn off wifi, selecting a different wifi network, changing the input language, etc) and every time the setup wizard crashes after the wifi selection page. I tried doing another factory reset (this time a hard reset, since I can't get past the Setup Wizard), and I'm still facing the same problem. :(
Repairlass1989
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 208 Answers
  • Posted on Feb 17, 2020
Repairlass1989
Expert
Level 2:
Passionate:
Answers
208
Questions
Helped
58984
Points
280
Try holding the power button and the volume up button same time when hear a vibrate realise them both
Asus ZenPad tablet has developed a very low volume problem!
Bonjour,
Le haut-parleur de votre tablette a peut-?tre subit quelques dommage.Vous pouvez voir cela avec un d?panneur:
https://www.distriphone.com/fr/2691-Pieces-detachees-Tablette-Asus
Tablet dont want to go to next page i factory reset it so it stays on language i tap on next n nothing
If your tablet is not proceeding to the next page after selecting the language during the initial setup, you can try the following troubleshooting steps:
  1. Restart your tablet by holding down the power button until it turns off, and then turn it back on again.
  2. Check if the screen is responsive by tapping on other areas of the screen.
  3. If the screen is unresponsive, try cleaning the screen with a soft cloth or restarting the device.
  4. If the problem persists, you can try resetting the device to factory settings again.
  5. During the initial setup, make sure to connect to a stable Wi-Fi network to ensure a smooth setup process.
If none of these steps resolve the issue, you may need to contact the manufacturer's customer support for further assistance.
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
1helpful
Does the ASUS ZenPad S 8 Z580CA-C1-BK 8 64 GB Tablet use a sd card?
If it does there will be a tiny slot on the side of the tablet, is there one??
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
1helpful
2answers
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
