Garden Logo
J Anz Posted on Feb 11, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a qualcast QSZ48B petrol mower - the rear wheel opposite the height selector is flopping about and wont maintain height of other wheels
Dan Apthorp
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 69 Answers
  • Posted on Feb 24, 2020
Dan Apthorp
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
69
Questions
0
Helped
17293
Points
166
I had one like that and I ended taking the wheel off and replacing the bolt or what ever what was loose and worn out. I even got parts off a junker machine and they worked. You can go to lawnmower repair shop if you wish.
5 Related Answers
Anonymous
  • 246 Answers
  • Posted on May 11, 2009
SOURCE: no drive
Hello orlywooldrid:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers (20622) and Click Search. Now Select View Assembly Drawings for your Year Model.
Everything you Asked is at the Above Site Addy.
Parts can Also be Purchased from this Site Addy;
http://www.outdoordistributors.com/
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Anonymous
  • 86 Answers
SOURCE: rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
Anonymous
  • 226 Answers
  • Posted on May 31, 2009
SOURCE: Mtd mower will not move forward or backward.rear
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
Anonymous
  • 67 Answers
  • Posted on Sep 01, 2009
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Anonymous
  • 16 Answers
  • Posted on Sep 12, 2009
SOURCE: height adjustment on my lawn mower
have the mower on a flat suface and adjust for the height you need on all four wheels then raise the rear of the mower by one hole to give clearance and reduce the loading on the blade
How do I adjust front wheel height?
Are we talking tractors or mowers here? If its a mower we are talking about there should be adjusters on each wheel. Possibly three holes that you bolt the wheels on. Each wheel should be in the same hole as each other wheel.
Jun 04, 2015 • Garden
How do ichange cutting height on honda petrol lawn mower
There are loads of different arrangements - the most common is a lever sticking out of the read of the machine that adjusts the height of the roller, and 2 adjusters for the front wheels.
Qualcast Motor Mower Starts but will not run
there will be a butter fly in the carb that pulsates this is conected to rev cable plastic may have snapped or cable come loose
take it it is petrol
Jul 29, 2012 • Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
The hover fly mower sits on the grass, being that there are no height settings, it cuts quite low. Are there way's to make the mower sit higher off the ground in order to cut the grass at a higher...
Usually all mowers have height adjustments of some kind. Look around your front and rear wheels, if you have a number of holes drilled into the deck ,these are your adjustment holes.You would unbolt the wheels and put them at the height you would like.
If as you say there is no adjustment, I would say buy new wheels that are an inch or more bigger than your present wheels and install them in place of your old wheels. If you go to any local dealer they will be able to help you with your problem.
Jul 03, 2011 • Garden
1helpful
2answers
Height adjustment on my lawn mower
Sep 12, 2009 • Garden
1helpful
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 • Garden
1helpful
How do i change wheel height on lawn mower
You do not change the wheel height, you change the cutter height,there should be an arm sticking up neart he rear wheel, you just push it to the side a little and push it either forward or backward.
Hope this helps
Apr 29, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
