Cell Phones Logo
V
Valucia Morris Posted on Feb 11, 2020
Why it is not possible to unlock my apple id?
Jasmeen Grewal
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 12, 2020
Jasmeen Grewal
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1547
Points
12
Maybe you have the wrong password. you can try resetting through icloud.com
2answers
When i m trying to download apps its sayng my apple id is disabled
Don't worry if your Apple ID has been disabled. Here I am to introduce 3 methods to deal with it.
Method 1. Fix the Issue on Apple Website (iforgot.apple.com)
You can use your email address or you phone number to unlock your Apple ID.
Unlock Apple ID by Email Address:
1. Visit Apple website (iforgot.apple.com), and you will see two instructions with one putting in your account and the other your password.
2. Enter your Apple ID and Password and you can unlock your iPhone.
3. If you can not remember your Apple ID, by clicking the bottom "Forgot Apple ID or password", you will enter a new window.
4. The website will ask you a few security questions to ensure that you are the owner. You need to put in the same information of "your first name", "your last name" and "email address" as you register the account. After typing the image of the character, click "Continue".
5. If you enter the information correctly, the Apple ID will be found. And you can click the "Go to Your Account" to retrieve the Apple ID.
Unlock Apple ID by Phone Number:
1. Visit Apple website (iforgot.apple.com) and click "Forgot Apple ID or password" at the bottom.
2. Enter an interface in which you need to put in your email address.
3. Click "Continue", you will get into a window where you need to put in your phone number.
4. Click "Continue" and enter "Unlock Account" window, it will ask you whether you want to unlock your account by your trusted phone number or one of your other devices.
5. Select either option whichever suits your situation and enter this interface, put in your phone number and click "Continue".
6. Enter your password and click "Continue", and you will find your Apple ID.
Method 2. Change your Apple ID Password
1. Launch iTunes on your computer and click "Sign in" at the top right of the window.
2. Select "Account Info" from the menu.
3. It will pop out a window and there's a "Forgot" on it, click it.
4. Basically your Apple ID user name will be pre-populated (if you forgot your ID, see "Fix the Issue on Apple Website"), and click "Next".
5. Then you will come to two options to prove that you are the owner of the Apple ID account: via email or using security questions. If you choose to verify by email, you will receive an email in your mail box, click the link on the email to verify. If you choose to use security questions, it will pop out some questions regarding you and the account. With the right answers you can be verified.
6. After finishing all this, you will be in a new window for you to enter your new password. Confirm the new password by putting it again, then you can reset your Apple ID password.
For more methods, check this guide. How to Fix When Your Apple ID Has Been Disabled?
3answers
2answers
I must reset my apple ID
Hi there, you can try TunesKit iPhone Unlocker to Remove Apple ID on Apple Cell Phones.
Here a step-by-step tutorial:
Step 1. Connect your iPhone to your computer
First, get your iphone connected to a computer. Then launch TunesKit iPhone Unlocker, and select the Unlock Apple ID option.
Step 2. Setting confirmation
If you have Find My iPhone enabled on your iOS device, you will need to confirm that a passcode is set and turn on two-factor authentication on your iPhone.
If the Find My iPhone feature is disabled on your device, you can skip directly to the next step and tap the "Start" button to unlock your Apple ID quickly without losing data.
Step 3. Remove Apple ID
Once confirmed, TunesKit iPhone Unlocker will start downloading the matching firmware and then remove the Apple ID from your iPhone.
I wish to unlock my Apple ID
What do you specifically mean to have your apple id unlocked?
Do you mean that you have lost your password?
My ipad is saying apple id disabled,how do I get it un disabled?
How To Resolve The Apple ID Locked Or Disabled Issue?
Well, if someone unfortunately tries to hack into the user's Apple account by entering the password incorrectly infinite times, or even giving various wrong answers to your security questions, Apple will further easily recognize the attack and will entirely lock your Apple ID. As researched by Mac technical support team, it's a good sign because it signifies that an attacker can't anyway gain access to the user's Apple ID to avoid allowing them get into a user's iCloud email, iMessages as well as FaceTime. However, it may often happen that it's not a hacker who is trying to get access to your account, sometimes it's only we who is getting ourself locked out of the account because we have forgotten the password.
Solutions to resolve the "Apple ID Locked Or Disabled Issue.
Solution1: Unlock the Apple ID Whatever the reason for Apple's disabling the account is, there is every possibility to get back into it. One simply needs to follow all these below mentioned tricks to recover their account and create a new password.
  • Go to the iforgot.apple.com section
  • Enter the Apple ID which will usually be the email address associated with the user's Apple account.
  • A professional team of Mac tech support experts have suggested to enter the Code to prove that a particular user isn't a robot.
  • Click on the "Continue" button
Solution2: This phase is based on the security process
Ā·If you are working with the set up two-factor authentication then it is quite possible for users to receive a code on a trusted device or as a text message on the phone. Users are required to enter the verification code before unlocking their account and changing the password.
Ā·If anyone is working with older two-step verification process, then a recovery key is needed that was sent to them while setting up two-step verification process in addition to a code sent to a trusted device.
Ā·Well, if a user haven't set up either of the above methods for security purposes then one needs to unlock the account by using their password, or simply has to answer few provided security questions at the some point.
Fix your Mac issues with expert team working at Mac customer support Toll-Free 1-800-213-8289 department and get all your headache resolved at a go.
3answers
Reset your apple id password
You can try TunesKit iPhone Unlocker to reset your Apple ID password on your iPod touch.
Here's a step-by-step tutorial:
Step 1. Connect your iPod to your computer
First, get your iOS device connected to a computer. Then launch TunesKit iPhone Unlocker, and select the Unlock Apple ID option.
Step 2. Setting Confirmation before Deleting Apple ID
If you have Find My iPhone enabled on your iOS device, you will need to confirm that a passcode is set and turn on two-factor authentication on your device.
Once confirmed, TunesKit iPhone Unlocker will start downloading the matching firmware and then remove the Apple ID from your iPod touch.
Hope it helps!
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
