It is a small indoor fountain for tabletop.It is musical too.The fountain pump is inside the structure and cannot be extracted.It is a Thomas Kinkade foiuntain
You have posted this query in a forum dealing with Camcorders. While we have every sympathy for your plight, you may get more help in a more appropriate forum
If it is the kind of fountain that you can open up and clean etc, you should do that. If it is a pet dish there is a good chance that the small pump inside that pushes water from the bottom to the top has gotten clogged up with pet hair. You should try opening it up, finding the pump, and if there is a build up of pet hair, clean it out and see if that fixes it. You should also be able to watch the pump working after cleaning it out to see whether it is still pumping or whether there may be another issue like a clogged filter elsewhere.
In the meantime, turn off the fountain and unplug it, as having the pump running but not able to **** in water will burn it out.
The most likely cause is a slow shutter speed, leading to image motion and camera motion. There's generally less light indoors than outdoors under the sun. This means that the camera needs more time to gather enough light to form the image. If the camera moves during this time then the picture blurs. No matter how carefully you hold the camera, you can't hold it still for more than a small fraction of a second. Try putting the camera on a tripod or a tabletop and see what happens. Also, the longer time allows for subjects (such as people) to move. Again with the camera on a tripod or tabletop, see whether people blur while the furniture comes out sharp. Another way to combat the blur is to add more light. If all the subjects are more or less the same distance from the camera and not too far away, you can use the flash.
Only safe way is to take covers off to get to the player. A common problem is jamming by a label that came off OR the little belt that drives the carriage has deteriorated or failed. Only way in either case is to open the unit.
An outdoor antenna is more better than indoor antenna. If we fix an indoor antenna, especially in rooms in a flat type structure buildings, due to its iron network structure reinforced inside its concrete will oppose a considerable obstruction to tv signals to get through. Moreover, if any paerson walk through these telescopic type antenna, picure will get shiver of it will be distrurbed.
So buy an outdoor antenna, and hoist it at suitable place, where there are no obstructions comes between the signal path of the transmitter and the antenna. Get an antenna, whcich has as many as cross elemets, if it is a yagi type. As number of elements increses, the sensitivity and seletivity of the antenna will also increase, resulting in good and detailed picture clarity. OK
That problem is a slipping drive belt. It is a small square profile belt near the front left of the machine. There is not enough tension and the motor spins its pulley inside the belt. The mechanism it drives is the load and eject function.
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
