I have also been facing the issue of Hp Recovery Manager Error Code ffffff15 for few weeks. But I search for its solution on the web. Where I found its solution through some blogs and articles. I can't post the whole solution here. So just do through the link provided and resolve the issue on your own through the original Post.
View Original Post:- http://www.hptechnicalsupportphonenumber.com/blog/how-to-fix-hp-recovery-manager-error-code-ffffff15/
SOURCE: I'm trying to be to
Hallo! You better make a bootable USB with Windows and try to reinstall the system from it. You may have dome damaged files in the recovery partition. The bad part is that you would search some drivers for your mini after reinstall. Cheers!
SOURCE: HP Backup and Recovery Manager
yes you can from here. just select you operating system and it's in the software - system management section next to the bottom of the page.
1. Error: BOOTMGR is missing:
• The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
