Garden Logo
Des Lopez Posted on Feb 03, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A BLACK & DECKER GB155 WIPPER SNIPPER PETROL
free again
Level 2:
Champion:
  • Expert 215 Answers
  • Posted on Apr 02, 2020
free again
Expert
Level 2:
Champion:
Answers
215
Questions
0
Helped
28713
Points
456
1 Related Answer
Anonymous
  • 490 Answers
  • Posted on Sep 11, 2010
SOURCE: i have a petrol black
50:1
Farmerbear
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
What do i do if no spark is coming form my Black & Decker Wipper Snipper GB155 con you please advise me regards Des
When checking for a spark you must make sure the spark plug is well earthed against the cylinder, and give the starter a good pull, if there is no spark try a new clean plug ( make sure the ignition switch is on ) if all this fails then unfortunately you may well need to fit a new ignition coil, this will be situated under the covers against the flywheel.
Using a black and Decker gb155 whipper snipper how do I adjust the high/low carburetor adjustment screws properly? And how do I replace the line so that it stops breaking
Dean:
Adjust the carburetor screws in all the way...do not force them. back the screws out one and a quarter turns and the machine should try to start. adjust the screws one at a time... one quarter of a turn until the machine runs properly. Then adjust the idle.
We can't loosen the screw on our black and decker GB155 to replace the cutting string
the screw will be left hand thread so turn it clockwise to undo it
Feb 18, 2018 • Garden
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Nov 21, 2010 • Garden
1helpful
Asked to repair a McCulloch wipper snipper model TM251SST+. Found fuel line inside tank perished as well as outside primer bulb. Replaced with new. The petrol does not pump up when primer bulb pressed. I...
the primer bulb has the valves in it ,check the in line fuel filter.take outlet off primerbulb,should pump thru from tank,thru the primerbulb
Jul 11, 2010 • Garden
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
