SOURCE: How to remove printhead from canon i860
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
SOURCE: Cannot remove the print head from canon i560
try this - open cover on printer
on the right side of the cartridges is a grey arm - lift it up
remove all ink cartridges.
then remove print head.
SOURCE: Figuring how to install new print head in my Canon iP90 printer
The important point is moving the head to the left, or sliding it left or right, so you can actually SEE the LEVER. It is hidden otherwise and what appears to be the obvious lever on the top is the wrong lever. If you have pressed the correct lever the unit removes very easily. If it is hard and you cannot make progress chances are you have not found the correct LEVER!
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
CAUTIONSee Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
CAUTIONCanon PIXMA MX922
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
