Kitchen Appliances - Others Logo
L
LuAnn McConnell Posted on Jan 28, 2020
How do you replace stir rod in stir crazy popper?
Elias
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Feb 04, 2020
Elias
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
17
Questions
0
Helped
3472
Points
32
You first need to stir it up
5 Related Answers
Anonymous
  • Posted on May 22, 2008
SOURCE: cord for stir crazy
Replacement cords can be found on the West Bend site:
https://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=39&linkon=category
Ekse
  • 13435 Answers
  • Posted on Jun 23, 2008
SOURCE: I need the stir rod
here
http://www.abtecparts.com/westbend_popcorn_82306.htm
farleyfam
  • Posted on Jan 20, 2009
SOURCE: 6 cup stir crazy popcorn popper lid
There are lids around your house that will fit this. Try a butter or sour cream lid.
Anonymous
  • 41 Answers
  • Posted on Oct 05, 2009
SOURCE: the wire in my stir crazy pop corn popper is broke
you can replace by a stainless steel rod
Anonymous
  • 581 Answers
  • Posted on Dec 21, 2009
SOURCE: No instructins with my west bend stir crazy
http://tricia8765.fatcow.com/HELPGUIDES.htm
You can download it from my website for one week. I will be updating and removing this link soon so make sure you save a copy of the manual.
Cheers.
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
1helpful
The stirring rod fell off. How do I fix this?
The center hub is screwed on. With the popper cold, try unscrewing the center piece. The stir wire sits in a channel under the center piece.
Rod will not turn when popper is plugged in
I once tried to get parts for a West Bend popper with no luck. I just kept using it without the stirrer.
I would say from a pure economic standpoint, you're better off getting a new one. I don't know that one brand is any better than another -- it's just potluck from my experience.
3helpful
2answers
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
