Question about Irons
Where can I buy a fuse for a shark g1405 iron
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Iron quit working in less than 1 year.
Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
Posted on Jul 19, 2010
Iron shark g1468n doesn't work
If it's completely dead (no lights or anything) then check the fuse in the plug by placing a new one in (same rating, probably 13 amp) and testing. If it's not that then suspect either the heat control (thermostat) or the element. These aren't your basic DIY things to mess with unless you know what you are doing.
Dec 08, 2013 | Euro-Pro Shark GI465 Iron
My shark pro iron shut off while i was ironing in never came back on.
Iron's have a thing called a "Thermal Fuse" these go "Faulty" or "Blow" very frequently, it is relatively simple to check and replace. Find the fuse, a small metal cylindrical thing, with a lead at each end. Use a meter set to OHMS and measure it, it should be a "Short Circuit" IE: 0 Ohms. If not it is faulty. But if it is IE: Open Circuit, NO reading, it should be replaced. It will have markings on it to denote it's type, get one the same, and replace it.
Feb 11, 2010 | Euro-Pro Shark GI490 Iron
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
Apr 05, 2009 | Euro-Pro Shark GI490 Iron
I have had 2 Shark irons and both simply stop turning on
The cost of repair is more than the cost of a new one. Therefore, trash it and buy a new one.
Mar 11, 2009 | Euro-Pro Shark GI490 Iron
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
Jan 18, 2009 | Euro-Pro Shark GI490 Iron
Shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Jul 05, 2008 | Euro-Pro Shark GI490 Iron
Irons Logo
22 people viewed this question
Top Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
