Question about The Computers & Internet
What are the 2 buttons on the left of my mouse for?
  • The Master
  • 5,727 Answers
What ever you want if you read the mouse manual
and use there mouse driver, those are programmable in the mouse settings
you posted to computers, is it? and if yes what is it.
no OS stated in your computer.
extra buttons can be used for some GAMES and some graphics editors, but most be enabled, first.
Posted on Jan 26, 2020
Anonymous
SOURCE:
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
The left mouse button does not work on my IBM
Windows has the ability to swap mouse buttons, mainly for those who mouse left-handed. It looks to the right button for left button action. It seems that the actual left button is not functioning. A work-around is to use the right button as the left as you are now doing, AND, use the solid windows button (the one to the immediate left of the right control key) as the right button. Not as easy, but it works.
Jul 18, 2009 | Lenovo ThinkPad R51
Mouse freezes when holding down the LEFT and RIGHT buttons
check out your mouse setting in control panel/mouse
May 10, 2009 | Laser LM8000WR Mouse
The left and right button feature has just reversed on my mouse
Is it possible the mouse is configured for a left-handed person?
Try opening the Mouse properties in Control Panel and checking to see if the mouse is setup for a left-handed person.
Hope this helps!
Mar 28, 2009 | Computers & Internet
Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Jan 02, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
CAN NOT DRAG THE DOC SCANNED TO THE FOLDER
Normally only the left mouse button works for dragging PDF file from one ScanSnap Organizer folder to another.
If the left mouse button will not drag the files to another folder, try the right mouse button. If the right mouse button is the only one that works, you have your left and right mouse buttons reversed (see the Mouse settings under the Windows Control Panal).
Eric
Sep 03, 2008 | Fujitsu ScanSnap Manager
Logitech downloads for V220 logitech mouse
You can get it HERE. Choose the correct operating system to download your driver.
Jun 21, 2008 | Logitech Cordless Mouse
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
