Page 1 P3PC-1432-08ENZ0 fi-5900C Image Scanner Operator's Guide... Page 3: Introduction INTRODUCTION Thank you for purchasing the fi-5900C Image Scanner. The fi-5900C is an image scanner designed to scan various documents in large quantities. The fi-5900C has the following features. This manual describes the scanning method using ScandAll 21.
SOURCE: fi-5900C Error code CDT008; CDT010 Bad handle
Please follow the link below to un and re install the device drivers.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
SOURCE: fujitsu fi 5900c i am
Hi have you got this sorted?, also need to know the detail code, hold down the two paper thinkness buttons at the same time you wil get a detail code, let me know what that is and ill try to help, unless you have it sorted, Cheers
SOURCE: I need ce manual for fujitsu fi 5900c. please help
Please send me an email to [email protected] and I will send the manual to you. Please put "Fujitsu 5900c" as the subject. Lawrence Brown
SOURCE: Fujitsu fi-5900C jams
Lift the Skimmer unit up so the scanner is in the manual feed mode.
Feed a Document into the scanner.
If the document passes through the transport without an error , then you have a skimmer fault.(unit with the pick rollers on).
Solution :- there are two magnet encoders on the skimmer .
Check them well for staple/metal fragments.
Another cracker from those Top secret guys and dolls at
[email protected] :):)
