First off it is not a computer at all why post this thing to computers?
let it sit for 24hours,batteries removed.l .
use fresh Type AA 1.5 V. batteries and see it work
never not try new batteries on any battery device that acts oddly.
you paid $600 for this thing , OMG too much.
worth $100 + $500 name Leica
Leica L
Leica Disto D510 (E7500i) 650ft/200m Laser Distance Measurer w/ Bluetooth and Disto Sketch App for iPhone/iPad - Red/Black
SOURCE: leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
SOURCE: I have a Samsung Q45
Since you have already taken it apart, open it back up remove the RAM, HDD, and CMOS BATTERY. Leave that battery out for a few minutes. Also while you have it apart, see if you can remove the CPU/GPU cooling fan, they always clog up with lent. Your problem sounds like maybe a faulty GPU. If you can hear windows boot an play music then your HDD and computer are working but you can't get VIDEO output. When hooking to external monitor did you push the FUNCTION KEY and the assigned F1 - F12 key to toggle the exterior VGA port on? Give these a try and comment back if you need more instruction. Hope this helps.
SOURCE: Have a Leica Disto basic and need to know how to
Press and hold the circle button down, after a few seconds it will flash 'beep on/off', dont stop holding it down, it will then cycle to 'units', press +/- to change between metric and imperial, then press the = button to store. If you keep holding it down you can set the reference pont (where the measurement is taken from, the back, middle or front edge of the machine) add an offset (add take away from the displayed dimension), and you can also reset the machine.
