SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
SOURCE: Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
SOURCE: Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
