Televison & Video Logo
Melisa Coffman Posted on Jan 22, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the setup button on my philips universal remote
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Mar 14, 2020
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002993
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
5 Related Answers
A
Anonymous
  • Posted on Jan 02, 2008
SOURCE: code for universal remote
0463
Anonymous
  • Posted on Feb 15, 2008
SOURCE: philips universal remote 4 digit codes
For combination tv/vcr the codes on the Phillips remote are 0039, 0739. I can only enter the channel I want to watch I can not use the up and down arrows for some reason.
sb2141
Anonymous
  • 2712 Answers
  • Posted on May 07, 2008
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Anonymous
  • 563 Answers
  • Posted on Apr 17, 2009
SOURCE: philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Anonymous
  • Posted on Aug 12, 2009
SOURCE: codes for durabrand tv with philips universal remote
I have a Durabrand TV and a Phillips universal remote... does any one know what codes i can use???
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 • Televison & Video
How to setup phillips universal remote to a panasonic tv
More items...
I'M LOOKING FOR THE 4 DIGIT CODES FOR A PIXEL TV TO SET UP A UNIVERSAL REMOTE CONTROL
How can I manually setup my universal remote control?
www.p4c.philips.com/cgi-bin/cpindex.pl?...
Philips LCD TV 32PFL7684H 81 cm (32") Full HD 1080p digital TV with Pixel Precise HD. 32PFL7684H/12. 32PFL7684H/12. Search for information about this product. Product ... Enter the 4-digit RC code of the device you wish to setup.
26PF7521D/10 26" LCD digital widescreen flat TV Pixel ...
Search for information about this product ... In digital mode, press the 'DIGITAL TV/MENU' button on the remote control to display the setup menu. Press the cursor up/down button to ACCESS RESTRICTIONS and press the cursor ... Note: If you have forgotten your personal 4-digit pin code, enter the universal code (0711).
Searching for Your Code - Universal Electronics Remote ...
www.urcsupport.com/html.php?page_id=314
1helpful
Need codes for phillips tv
Hello
Three digit universal remote code for Philips TV are:
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit universal remote codes for Philips Magnavox are:
183/ 184/ 208/ 213
Four digit universal remote codes for Philips TV are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit universal remote codes for Philips Magnavox are:
0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
I cannot find the code for my magnavox tv. can you send me the possible remote control codes?
Hello
Three digit universal remote codes for Magnavox are:-
183/ 184/ 208/ 213
Four digit universal remote code for Magnavox are:-
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Four digit universal remote code for Philips are:-
Four digit universal remote code for Philips Magnavox are:-
Direct Code Entry
OK.
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • 0helpful
    Need to program my tv and dvd player to the remote
    Please follow the steps below
    Program the First Device by Entering Direct Codes
    2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
    3.Release the Setup button
    4.Press the TV button.
    5.Release it immediately and make sure the indicator light is illuminated.
    7.If the device responds, you have successfully programmed your Philips universal remote.
    8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
    6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
    7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
    To get the universal remote codes please visit below solution
    http://www.fixya.com/support/t5395701-universal_remote_code_phillips
    Thanx
    Do you have to reprogram the remote after changing the batteries?
    It depends on the remote model.
    After changing the battery please check weather the remote works or else you need to reprogramme it.
    For programming please follow the below steps
    1.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button.
    2.Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV or DVD button.
    3.Release it immediately and make sure the indicator light is illuminated.
    4.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
    5.If the device responds, you have successfully programmed your Philips universal remote.
    6. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds
    Thanx
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
