Question about Inverter Electronics - Others
I have kenwood dc inverter which shown 36 error
LG AC CH23 error how to clear this
ch23 Inverter dc voltage low. Check dc voltage of capacitors 300 Vdc for 1Ph and 600 Vdc for 3Ph. If OK change outdoor inverter PCB
Jun 07, 2018 | LG Washing Machines
OH error in toshiba inverter VF S11
Follows are the part of the manual
Possible causes
• The cooling fan does not rotate.
• The ambient temperature is too high.
• The vent is blocked up.
• A heat generating device is installed close to the inverter.
• The thermistor in the unit is broken.
Remedies
Restart the operation by resetting the
inverter after it has cooled down enough.
• The fan requires replacement if it does
not rotate during operation.
• Secure sufficient space around the
inverter.
• Do not place any heat generating device
near the inverter..
May 03, 2014 | Toshiba Electronics - Others
Hp 3600 54.17 error
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
15 Yellow
16 Magenta
17 Cyan
18 Black
1. Make sure that connector J1020 on
the DC controller is seated correctly.
2. Replace the DC controller.
Dec 12, 2012 | HP Office Equipment & Supplies
Error 68.2 on HP laserjet P4015n
If you are unable to solve this problem using above mention solutions then you can try this one. Open all covers and then detach the DC controller board that is shown In picture below. it is the back side of DC controller board.
With this DC controller board you can see another small circuit bard that is attached with DC controller board with a white (ribbon) cable. I found two printers with this error when I examine the board I found that the thin print wires are broken as shown in the following picture. I have to connect these wires with soldering and now it is working fine.
If these printed wires are ok then you can check the ribbon cable .check all connectivity with Multimeter.
First you solve this problem with software.
Then try to find disconnected wires or dry soldering on circuit board.
Last you change the Dc controller board because the problem is in surly in DC controller board.
Aug 08, 2012 | HP LaserJet P4014n Printer
How to get a symmetric DC power supply : i.e +18 Volts -18 Volts and ground from this kenwood power supply PDS36-20
You can't do that because it's not a split supply. There's just a single output referenced to ground, so all you can get is one voltage at whatever you select from 0 to 36 volts.
Aug 01, 2011 | Kenwood (PDS36-20) Power Supply
Lg out door unit shows a CH23 error.What could the problem be? Could this mean that the PC unit has gone. Thanks Joe
Inverter dc voltage low. Check dc voltage of capacitors 300 Vdc for 1Ph and 600 Vdc for 3Ph. If OK change outdoor inverter PCB. Helpful?
Jan 04, 2011 | LG Heating & Cooling
My HP dv6000 laptop screen goes black suddenly, without warning. It is solid black if on battery power; if I have it plugged in to power supply, it is black with flickering white lines.
Your inverter is failing. Under battery power there is not enough DC power for the inverter to convert to High voltage AC power and it goes black. Even under charging, there seems to be evidence that the inverter is failing because there it is unable to consistantly convert the needed power. Check the cables on the back of the display and change your inverter.
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Machine error 36
There are several reasons for that:
check travel path of the print head. Any obstacles there?
Does the purge station work well?
Is your power outlet fit enough, or did you had some lighting strikes the days before? It could be another indicator for a weak power supply (ac or dc!)
Nov 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Electronics - Others Logo
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Larry Ng
Larry Ng
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
