Top Solutions The manual that comes w/the uni-remote usually has several codes avaialable for the different brands listed keep trying several codes till ... read more Call the place where you got it from. In your Emerson manual, there should be something to help you :) ...
Read more: How do i autoprogram a lm-1079 universal remote? - I want to know how to autoprogram a lm-1079 remote it has no "setup" buttons? It was bought at Dollar General Store :: Ask Me Fast at https://www.askmefast.com/How_do_i_autoprogram_a_lm1079_universal_remote-qna8733473.html
SOURCE: tv code guide
go to www.retrevo.com they have all the manuals and codes in Adobe PDF files frree to down load you just have to register you email address.
SOURCE: the Audiovox Rca RCRN04GR Universal Remote Control
Try to Google the model numbers of each for "manual" to see if available.
SOURCE: How to auto program a phillips universal remote to a memorex blue ray player?
0483,0481,0488,0497 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
SOURCE: How to set up universal using code search no name on remote it just has lm1079
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order.Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window.It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
SOURCE: need codes to program lm1079 universal remote. to Sony DVD
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
