SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
SOURCE: Troy Built Snow blower won't start.
Cleaned out caruretor and blew out presumed dirt via compressed air. Thanks for your support.
SOURCE: MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight.
