Https://www.youtube.com/watch?v=3R_RYO6jSOs
E21. Canister fill pump triac faulty. Possible fault Wiring faulty; Electronic board faulty.
https://www.how-to-repair.com/help/e21-e22-error-code-tumble-dryer-pump-fault-aeg-electrolux-zanussi-etc/
SOURCE: Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
SOURCE: Kodak easy share z700 is showing error code e21
you need to reinstall the firmware. see this link
http://support.en.kodak.com/app/answers/detail/a_id/1298/kw/error%20e21/related/1/selected/true
SOURCE: Error code E21
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to the Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try using compressed air into the drain hose at the rear of the washer. No disassembly required. It only took a minute to do from my compressor. I suppose it would be just as effective with a garden hose, but a little more messy. Anyway, 100% problem solved! No more error code, and as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained. No repair bill. I just hope that whatever was restricting the drain flow does not happen again.
SOURCE: Hoover AAA 160 Washer error code 4
opened the back cover and used tissue to dry inside. Then it was OK.
This really comes under the category of laboratory equipment, not digital cameras, I'm afraid.
I appreciate your inquiry, Bill Payer!
I understand that your Electrolux range is displaying error codes "E21" and "E39" and you are waiting for a part to become available to change. Based off the error codes "E21" stands for key sensor for cook place two which means a potential issue with the left board. "E39" stands for incorrect configuration. To configure your cooktop you would need to press and hold the "Warm" key, then press right front "Power" key until it beeps. Then press left front key and the configuration should start. If that does not help your situation I would suggest having a professional out for proper diagnosis. This will help to avoid any unnecessary part purchases. Best of luck! -Matt
