Check for power ---use a meter to test thermostat and compressor
The compressor is what causes your cooler to cool down. If the compressor is not working properly, it could cause temperature issues. The compressor may, for some reason, not be getting enough power, and it is not starting properly. Alternatively, it may be overheating, causing it to malfunction.
https://www.abaapplianceservice.com/about-us/blog/4-reasons-your-wine-cooler-is-not-cooling.html
SOURCE: Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
SOURCE: Haier BC112G Wine Cooler will not maintain temperature
same problem. I just replaced the sensor but the temp just keeps dropping . Its sitting at 28 degrees now !
I've looked for a thermostat but cannot find one .
SOURCE: Wine temp on Haier wine
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
SOURCE: need cooling fans for haier
http://www.repairclinic.com/PartDetail/Fan/1222948?modelNumber=HVW18ABB
