If your Pfaff 1469 sewing machine needs a hand tug to get it running every time after pressing the foot pedal, it could be due to several reasons. Here are some steps you can take to service the machine:
- Clean the machine: Dirt, lint, and debris can accumulate in the machine, causing it to jam or run slowly. Use a brush or vacuum cleaner to remove any debris from the machine.
- Oil the machine: Lack of lubrication can cause the machine to run slowly or seize up. Use a good quality sewing machine oil to lubricate the machine according to the manufacturer's instructions.
- Check the foot pedal: The issue could be with the foot pedal. Check for any loose or damaged wires, and ensure that the pedal is properly connected to the machine.
- Adjust the tension: If the machine is not properly threaded or the tension is too tight, it can cause the machine to jam or run slowly. Check the threading and adjust the tension as needed.
- Check the belt: If the belt is loose or damaged, it can cause the machine to run slowly or not at all. Check the belt and replace it if necessary.
- Check the motor: If none of the above steps resolve the issue, it could be a problem with the motor. Check the motor and wiring for any damage, and consider having it serviced by a professional if needed.
It is important to follow the manufacturer's instructions when servicing your Pfaff 1469 sewing machine. If you are not comfortable servicing the machine yourself, consider taking it to a professional for repair.
Hi Janet Rice, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
