Heating & Cooling Logo
Darrell Morrissey Posted on Jan 19, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pilot light went off when using,did notice outside stack has a lot of ice on it though
Level 3:
  • Heating & Co... Master 19,187 Answers
  • Posted on Sep 16, 2020
Level 3:
Answers
19187
Questions
0
Helped
4341899
Points
82259
Ice accumulation is normal due to condensation from the temperature change. The condensate then turns to ice when it is below freezing. Pilot lights can go out when the thermocouple fails or there is high wind coming down the flu or against a side of the building with a lot of air leaks
3 Related Answers
Robotinner
  • 66 Answers
  • Posted on Dec 15, 2009
SOURCE: We have a Model # 3003622 Williams Gas heater. The
yes clear the ice and clean the pilot assembly sounds like the flame is being retarded by a dirty pilot orifice
john224
John Prohaska
  • 1378 Answers
  • Posted on Mar 17, 2010
SOURCE: pilot light wont stay on
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Anonymous
  • 52 Answers
  • Posted on May 11, 2010
There is a thermo couple that keeps the gas on. The pilot light bracket has a small screen where the gas comes through that can get clogged and cause the pilot light to burn away from the thermo couple which would cause it to think the flame has went out and shut the gas off. Or the thermo couple has went bad itself. If you try cleaning the screen use canned air and gently blow it through the orfice once you have taken it off. If you don't know what a thermo couple is or looks like here's a picture of a generic one that will give you an idea. Usually there's a bracket that holds this in place. f1b528a.jpg
2answers
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
A.O. Smith ProMax Plus GVR 50 101 Safety Question
You need to inspect and clean the air intake located on bottom of unit. Get more fresh air to the water heater and see if problem continues.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Instructions for lighting the unit are located on front of water heater.
Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances.
Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
2answers
Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition...
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Pilot light wont stay onfor outside pool heater. Gas co made a service call & relit the pilot light it went out again 4 days later.
May 09, 2010 • Pool & Spa
2helpful
4answers
I HAVE A VERMONT CASTINGS RADIANCE HEATER MY PILOT LIGHT WONT STAY LIT I HEAR THE THERMOCOUPLER TRIP THE VALVE BUT THE FLAME WILL GO OUT
We had this problem and struggled with it for over a year. We finally hired someone to come in and service the stove he cleaned everything and blew a piece of crud from the pilot line. NO Problem for 2 years since.
He told me the pilot light should look strong pointed like a pencil not curved up like a candle. He removed the pilot and disassembleed the line and used compressed air.
3helpful
2answers
The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Pilot flame starved out after burners ignite
The declining pilot light might be an indication it is being starved of oxygen by the main burners or some other sort of circumstance.
I have noticed how in a closed room without ventilation the pilot light soon begins to decline and then springs back again when a window or door is opened while the main burners are hardly affected.
This is the gas equivalent of sending canaries down coal mines and is an essential safety feature. If the pilot light declines very much the thermocouple bulb will not be heated and the gas supply to the main burners will be cut off. This is why the pilot light is set at an angle and the thermocouple bulb is slightly offset.
I am not sure if this helps but I hope it does.
Mar 08, 2017 • Ovens
Pilot will nost stay lit!
you could be right it could be a dirty pilot remove the pilot assembly and clean it has an orifice inside where the gas has to pass through its about the size of the point of a pin so its possible that its clogged, if this doesnt work the thermocuple might be bad
2answers
Heat Pump Not Performing up to par...
This sounds like a small freon leak. If you have a low pressure cut out switch, it should cut the compressor off before it gets too low. If you have a lot of ice on the outside coil, then maybe the defrost board or the sensor has went bad. But because you said it is running continuously, I think its low on freon. Unless you own a set of gauges for this equipment, call a pro.
Top Heating & Cooling Experts
Paul Carew
john h
