There is a reset button this unit. It's close to where the heating element comes out of the black box. You have to slide it out of the base to press it with a pin or something thin. Also, make sure the box slides into the base all the way. There is a safety switch in one of the channels that slides into the base. If the unit is not in the base it won't turn on.
SOURCE: wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
SOURCE: Rival Deep Fryer
about the Lid, make sure that you have the control panel firmly in the two grooves and the lid will stay shut. If it isn't in the right grooves, the lid will not shut. My husband had to point that out to me when I was having the same problem.
SOURCE: fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
