SOURCE: epson stylus photo 895 error code
1Eb means no black ink, 1Ec means no colour. Change the cartridges and you should be good. you will need Epson cart numbers: T007 Black T008 Colour
SOURCE: epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
SOURCE: I have a error on my epson cx6400 and don't
the best way to solve the problem is to replace the printheads or
Turn the printer on and pull the plug when it starts its initialization process. Can you move the carriage by hand at this point? If not, sounds like you may have a carriage motor\belt issue.
or clear the error message.
Thanks,
SOURCE: Epson WF-2650, bran new, already shows error 0xF3. How to clear?
Error Code 0xF3 means a hardware failure. Call Epson....
