A little more info may be needed. Does your TV say this as soon as you plug in your firestick or does it say this when you are trying to play a video? If the first hold down rewind "<<" while holding top circle of remote (outer ring) for 15 seconds. It is likely that your TV resolution is out of spec for the Firestick (4k?) and you will need to enable "legacy" (older) resolution mode on the Firestick. If this does not work, there are you You Tube videos on enabling this mode for your Firestick. If the second, then you are trying to play a video with an unsupported video Codec, in which case you would need to find a supported video.
SOURCE: Need help with Media Player
Solution to your problem:- The Core Pocket Media Player (FreeWare) Download it from here:- http://picard.exceed.hu/tcpmp/test/ If you want to download it directly on your phone click on tcpmp.pocketpc.0.72RC1.cab Otherwise:- tcpmp.pocketpc.0.72RC1.exe TCPMP supports many audio, video, and image formats, including AC3, HE-AAC, AMR, DivX, FLAC, H.263, H.264, JPEG, Monkey's Audio, MJPEG, MPEG-1, MP2, MP3, Musepack, MS-MPEG4-v3, PNG, Speex, TIFF, TTA, Vorbis, WAV, WavPack and XviD. It supports many container formats, including 3GP, ASF, AVI, Matroska, MPEG, OGG, OGM and QuickTime.
SOURCE: Philips Gogear 1GB - File format not supported
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sure you are connected to the internet first).
SOURCE: Philips 4GB GoGear Flash Audio Video Player - Video Error
just download youtube converter it is freeware.add the file ,choose the format i.e avi ,get the output file .now load it on philips media converter it will read and work.
SOURCE: I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
SOURCE: screen frozen
I've had this same problem and we only bought this TV back in July. It seems to be getting worse. Anyone have any answers?
