SOURCE: I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
SOURCE: kenmore model 110 will not start drain cycle-top load washer
If the machine agitates, you probably have a bad pump. This is pretty straightforward repair, and I'm sure I can help you if you think you can do this yourself. Follow this link to a previous explanation on cabinet removal and you will find the pump right in front of you when you get the cabinet off. The part is relatively inexpensive to obtain from a local appliance part store. Changing is very simple. Hope this helps you :)
http://www.fixya.com/support/t2827272-kenmore_washer_model_23922200_not_spin
SOURCE: FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
SOURCE: error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
