Coffee Makers & Espresso Machines Logo
C
Charyse Posted on Jan 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dumped beans in without the pot in the bottom and I can't get the beans out. Should I take it apart?
jws1013
Level 3:
  • Master 1,713 Answers
  • Posted on Jan 16, 2020
jws1013
Master
Level 3:
Answers
1713
Questions
Helped
458190
Points
6786
We don't know what "it" is. It would help us if you stated what brand and model you are working with. Try re-posting with additional info on the machine.
1 Related Answer
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Feb 26, 2010
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
Temperature issue please help. KitchenAid Crock pot KSC6223SS
Hello. I am fairly certain your slow cooker is defective. That is a 600W model, while most are only about half that. I suggest you put 2 cups of water in the cooker, on high and check the temp after 2 hours... compare that to other slow cookers you have. If you have a Kill A Watt Meter, you could use that to test it.
Overall though, I would try to get the device replaced under warranty.
Machine says refill bean but its filled
Hello Penny McEwan,
After two lifetimes in electronics... my highly sophisticated electronic background says ...
Get a clean paper sack.
Unplug you unit... and invert the MACHINE pouring the beans into the sack... While holding the machine in that position fetch it a good smack (one on the north side & another on it's south end).
Set the machine back down... like you mean it (good little bump to loosen any coffee bits)... pour the beans back into the hopper...
Plug the little beauty back in and
you should be ready to brew
Else ... get a clean paper sack... (blah blah... blah)
empty it ... smack it... vacuum it out (try again)
Take it to your repair shop!
As for me... after two life times: I still have all the toys...
all put away... nice & clean on the shelf...
I boil 12 cups in a 3 quart pot...shut off the fire and dump in the fresh ground beans let the froth settle (about 5 to 10 minutes)
and pour my first cups through an old fashion Melitta #6
(un-bleached) filter into a 10 cup Melina pot ...
or Chemex carafe
Better than a FRENCH PRESS... camp-fire style without
DRINKING the grounds...
Adjusting the flavor by varying my dark roast between
ITALIAN & FRENCH... with a half mix of PEETS
(Major Dickason's) whole bean... Yum...!!
Big, bold and just like a great big chewy CABERNET
Sauvignon... (CAN'T SEE THROUGH IT).
Never ever leave it on the heat...!
(use the microwave to reheat... or just try ice coffee).
Filter & all goes into the compost
Costco sized cups, bags & 55 gallon drums (of course)
Hope this helps!
Seaco Syntia - Displaying "No Beans" even when the beans are full
First, I'm NOT a Saeco technician, But I have worked on similar machines. (I still have one in my garage along with other 'graveyard' coffee machines.) Check your warranty and call for service as there are no customer serviceable parts in this equipment.
*** the following is for information only ***
* I've taken these machines apart many times and found there are a lot of sensors in this unit. Many are very delicate and fault out easily. If you do locate the right sensor, you will still need to locate a replacement. Ordering parts can be a challenge as it must be the correct model (and serial number series). I found out the hard way that not all PC boards are the same as the change functions even in the same model.
* Okay looking around I came across a vid (link below) that shows in detail how to check all the functions of the model he has. You probably don't need to go through the descaling and other checks. The Bean grinder portion is very detailed and not for the faint of heart. But his instructions are clear and should be able to solve your problem. His "No Bean" error was caused by prolonged use without proper cleaning and someone spilt water into the bean cup long ago. I hope to try out his method soon as I never took apart the grinder section completely like he did. I only vacuumed the beans out.
Good luck (to all of us!)
Aloha, ukeboy57
https://www.bing.com/videos/search?q=Seaco+Syntia+no+beans&&view=detail&mid=7D35DEE54A6DBDC3688B7D35DEE54A6DBDC3688B&&FORM=VRDGAR
Jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
2helpful
3answers
Miele Coffee maker cva 615 coffee will not come out
The screens that the coffee grinds are squeezed in between are clogged. You need to remove the brew unit, remove the bottom screen, (should be one phillips screw in the center) and scrub the screens clean. You need to clean all of the really fine holes out so that the water can pass through. To prevent this in the future, use the rinse cycle on the machine frequently and also take the brew unit out and rinse it under hot water everytime you dump your waste unit.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
