I might have found what you are looking for. Hope this helps
https://www.google.com/search?q=john+deere+68+wiring+diagram&rlz=1CAHKDC_enUS852US853&sxsrf=ALeKk03ipOPFZ7QcQd0BAUffhXaoYqaOUw:1585804644030&tbm=isch&source=iu&ictx=1&fir=X8yxPH2HO4Wp8M%253A%252COHXOeGYGh1UWXM%252C_&vet=1&usg=AI4_-kS24tK3qgqTmjaCUHzEnBLlzLwL5g&sa=X&ved=2ahUKEwj1_PXT_sjoAhXpB50JHZAjC78Q9QEwAnoECAkQFw#imgrc=X8yxPH2HO4Wp8M:
SOURCE: I'm lloking for a wiring diagram for a garden
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet
This link shows the complete wiring harness for a 110
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
SOURCE: How do I replace the
These links should help you get a manual and the instructions are in there. If you need more help or step by step help please contact me. Thank you.https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_345_48CdeckLawnTractor.pdf https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.publicservlets.HomeUnsigned
SOURCE: Do you have a wiring
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
