SOURCE: No dial tone
my base unit did the same.... power from the wall was out ... check GFI switch.
SOURCE: Phone not working
If the VTech is plugged into a different phone outlet than your touch-tone, then I know what your problem is. There are two wires that are hooked up inside the outlet box that run to the jack that your phone cord plugs into. One wire is for the "ring", the other one is for "tip". If these two wires are hooked-up backwards, it will cause you to have a dial tone whether you press any number buttons or not. Don't fret...it's an easy fix. If you pull the cover off of the outlet and reverse the wires meaning that if depending on which two are hooked up to the jack, whether it's the black and yellow pair, or the red and green pair, all you have to do is loosen the two screws that are securing the two wires that are going to the actual jack, and reverse them. Then just tighten the screws back up and replace the cover on your outlet. You should be ready to reach out and touch someone immediately! Hope this helps and have a great day!
SOURCE: No dial tone and base is constantly flashing red
http://www.uniden.com/products/productdetail.cfm?product=ELBT595
Here is the link to the manual...
But have you tried:
1. charging the unit for 10 hours?
2. registering the handset?
Register expansion handsets to the main base
Before the expansion handset is registered, the battery pack MUST be charged for 10
hours.
To register an ELX500 handset, simply place it in the main base.
To register a TCX860 handset, follow the steps below:
1) From the base, press menu/select and select S y s t e m
S e t u p menu.
2) Select R e g i s t e r H a n d s e t, and press menu/select.
3) On the handset, press and hold # until you hear a
beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
Customer Hotline at 1-800-297-1023. (Mon - Fri 7 am to 7 pm,
Sat/Sun 9 am to 5 pm, CST. Phone support is closed on holidays.)
SOURCE: My cordless phone says No link to base Move closer
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
