SOURCE: Motorola h15 bluetooth listen to music on android
This headset only allows for handfree profiles. You need a bluetooth stereo profile or A2DP profile. I'm afraid you can't listen to music using this device.
Hi
Your Micromax has an audio player built in, so if your headset is working with the phone for calls then when you have music (say mp3) files in the memory, or an SD card then when you tap the music player icon the player will start and you can listen to the files that are on your phone.
The full spec for your phone can be found here:
Micromax Canvas Fire A093
Hope this is helpful, if so would you please register that with Fixya
Cheers
SOURCE: how to connect motorola h350 bluetooth device for listen the music in our android phone
Go to Settings on your phone turn on device as you start your Bluetooth on your phone. They should find each other and pair automatically but if they don't, turn off the device and then on again then immediately touch "scan" on your Bluetooth setting on your phone. If a new device shows up after scanning under "available devices" touch the new device name and it should pair. Good luck!
