Press the home button and then select copy by pressing the up arrow and then press the OK button and also press the OK button to adjust the copy settings. Under settings, make the correct changes: If you are copying a photo the layouts should be set to Borderless or With Border and Document Size set to the size of your papers.
Broken fixing heater wire
? It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
? It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
? It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
Hi Nash hodge, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
All that is posted was 'how can I fix this problem
In general terms, you have to know when to hold them, know when to fold them, and when to run.
