SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
SOURCE: On the piece that covers the brushbar and motor
In theory, yes. If the brushbar isn't held firmly, then the belt isn't running smoothly which puts more strain on the motor. This can cause the motor to get hot very quickly which will trip the thermal overload protection.
After it switches off, do you have to wait several minutes before it will turn back on?
SOURCE: need to know how to drain a warnock hersey hot tub
Only way to drain that spa is siphon out the water and then use a shop-vac to get the rest out, sorry that tub is kind of a pain.
Testimonial: "Excellent solution! That is what I indeed ended up doing- it's just like draining a waterbed. I used the shop vac to start the suction."
